Toshiba estudio167
  • logan1978
    • Jul 2025
    Toshiba estudio167
    Hi:
    I am looking at Toshiba estudio167 to replace our xerox copier and HP5100DTN in our Engineering office. Our copy needs have dropped significantly since we moved to a electronic drawing system and we no longer have to make duplicates for drawings. So we are looking for a solution in the $1000-$6000 range that can met our 100pages/day needs and allow us to scan and make the odd copy. Our xerox sites turned off most days.
    Requirements are:
    2 tray
    letter and 11x17
    duplexing
    Scanning/copy
    Network wired.
    Color is an option but if it puts it out of our price range it can be sacrficed.
    Thanks.
  • logan1978
    So is this a good machine is it a dog and can you recommend something better?
    • tsbservice
      Field tech
      • 8007
      It's good low volume machine. It will work at 100 copies per day, but you may consider an eStudio233 series, much better machine. Price per copy is similar, and both machines will need some options added to meet your needs.
