ADD PAPER
  • esam ramadan
    • 199
    ADD PAPER
    i have TOSH5570 give message of ADD PAPER in 2nd cassette although i put the paper inside it , i changed the cassette , feeding unit , lifting motor,and the sensor in the back of ms but nothing helped i saw and heard the cassette tray move and lifting paper but the still give the message
  • esam ramadan
    • 199
    any help plz
    • emujo
      • Jun 2009
      • 3009
      There was a firmware problem that dealt with tray feeding. Unplug the finisher and see if problem resolves. If so update firmware to latest (easiest way to do this is just buy the EEproms from Toshiba). Also, there is a blurb in the 8070 handbook that states if you have a C15,16 or 17 error code, the affected tray is disable and the LCD screen will reflect "add paper" for the problematic tray. Look in the error history for these codes. You can also test S33 (Paper Empty) and S47 (cassete detect) in the I/O mode (power on with 0/3 depressed). With Energy Saver LED Off press #4 key and pull casette in and out.. "G" should alternate states if sensor is working. For the tray empty sensor, you'll have to stick your hand in the feed section and manually flag S33. With Key#5 depressed, "D" should now alternate states. Good luck. Ed
      • esam ramadan
        • 199
        thanks alot emujo
