E Studio 282 & GM-2071
  • Nazakat
    • 67
    Dear Friends !
    Does GM-2071 works with e studio 282? I need GM-2070 for e studio 282 but i am told now its part number has been changed to GM-2071.I just wanna know it will enable my e studio 282 print/Scan function or it supports only e studio 283?
    Mr.Spock Any Idea Sir !
    Thanks in Advanc
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    This will work if you have the latest firmware installed.
    • Oystercopy
      • Oct 2009
      • 618
      Spock... Is that true?
      Can you really use OLDER Enablers with the right firmware...? I had NO IDEA.
      • ivovb
        • 695
        Yes it is true. I can confirm it that in THIS case you can.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • Mr Spock
          • Aug 2006
          • 2064
          Actually the gm2071 is the newer dongle and needs I believe it is v321 or higher firmware to work. The older gm2070 is suppose to work irregardless of the firmware level. And this is true on all the machines that the dongle was changed by 1 on the last number. The older dongles work on all firmware levels but the "new" dongles work with basically the latest and greatest firmware only.
          • Oystercopy
            • Oct 2009
            • 618
            OMG... (to borrow a phrase from teenagers....)
            If I had known this, I could have saved a TON of money buying the old Enablers... JEEZ.... Toshiba and their games. Like making a new part number toner for the e-283's instead of keeping it the old part number. And changing the toner cartridge slightly so it don't fit... hmmmmm
            • serge_039
              hello
              Im new here and i just recently bought a toshiba gm2070 and it came without the usb dongle. I just want to know if its possible to make it work without it?
              Thank you for your help
              • Mr Spock
                • Aug 2006
                • 2064
                Originally posted by serge_039
                hello
                The gm2070 is the usb dongle. This is good for the es202L, 232and 282 models.
