Toshiba 452 after 25-30 copies coming "wait"
  • waqas_pk
    • 18
    On toshiba 452 after 25 to 30 copies appearing "wait" on lcd for some time and copies are stopped after some time machine gets ready again and starts copying again. i try to rebuild database by 08-684 then 08-947.and i also did format hdd by 08-690.i checked the toner supply ratio and its ok. and i also checked the toner feeding and thats ok too. Any idea or any solution plz....
  • Guest
    Replace HDD and firmware.
    • hoff247
      • Jul 2009
      • 25
      Check fuser temps. I have seen this a few times on machines where techs set fuser temps too low. I normaly set mine on 190 C. Anthing lower could cause your problem.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        How much toner is in the bottle???? Just because the tcr is correct does not mean that the toner is available.
        • ToshibaTech
          • Apr 2007
          • 580
          My money is on gunked up thermistors.
          I will not give you service manuals or firmware.
          • waqas_pk
            • 18
            thanks for replying .Mr. hoff247 i have already checked fuser temp and it was OK. and Mr Spock dev drum toner is replaced with new parts . and only thermistors i did not checked now i have to check the thermistor also, may be this suggetion works .again very thankfull to All you seniors.
            • ken5
              not only 452 in e35 also hving this type of problem
              try to replace the hdd
              • mitsubee
                • 176
                Replacing HDD doesn't help at all.....Try on toner & heater issues...
                • levino
                  • Jul 2009
                  • 38
                  hai
                  replace the power pcb
                  • ken5
                    if still cannot
                    u only need to replace the thermistor only
                    • mr_toshiba
                      mr_toshiba of egypt
                      • 3
