Heyas
We have a windows 2008 64bit server with the PLC drivers installed and shared. When the client connects to the drivers all is ok until they try and print. There is about a 20 second delay, as in the mouse will just turn into an hour glass, then it will unhang and start printing. It also does the same thing when clicking on printing preferences, hangs for about 20 seconds then comes up.
When the drivers are installed locally on a workstation it is all instant. Also if using the driver from the 2008 server its self there is no delay on printing or going to the properties.
Also if you download the 64bit PS driver for 2008 server it will not install, it says that it is not supported and will not install!! Even that on eid.toshiba.com.au drivers section it says 64bit 2003/2008 server etc!!
Any help would be great thanks guys!
Isaac
Isaac
