toshiba 1370 copier
  • npauline
    toshiba 1370 copier
    The wrench symble comes up on the display with no error code fuser does not come on
  • deep
    • Jun 2008
    • 208
    Press C and 8 at the same time then the error code will show up.
    Kenny
    • Guest
      Yep Hold Down Clear and 8.
      If C7 Error.
      Hold down 0 and 8 at power on.
      Input 69 and clear the error by puting in 0 then the print key.
      If error comes back check the Thermo Fuse and Thermistor and Fuer Lamp.
      Prob the Thermo Fuse.
      This will Fix It.
      • hoff247
        • Jul 2009
        • 25
        if c7 then input 89, not 69. Set to 0 then press start.
        • nathansipe
          just another tech
          • Aug 2009
          • 122
          He's right, its 89. set to zero, press start and the machine should come to ready. If it comes back then I've found that 9 times out of 10, just clean the one thermistor and thermostat (thermofuse). That should take care of it.
          Best rule for troubleshooting.
          K I S S Keep It Simple Stupid
