eStudio 2820c : Wireless and wired connection at same time
  • josuast
    • Aug 2025
    Is it possible to connect wireless and wired LAN to use both connections at same time?
    For example, I run wired on 192.168.0.0/24 and wireless on 192.168.1.0/24 and separate out segments of a network.
  • ivovb
    • 695
    Machine itself can not do it. You need external solution.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • emujo
      • Jun 2009
      • 3009
      On the older Toshibas, you had to run the ethernet cable from the MFP's NIC to the wirless option. If new products are the same then no.
      • sdrawkcab
        Confused & Bewildered
        • Jun 2009
        • 317
        You can't run a wireless and wired at the same time, but you can use a USB print server thru the USB port and achive the same thing, ie, 2 different LAN networks on one copier.
        Some days, it's just not worth chewing through the restraints
        • TheOwl
          • Nov 2008
          • 1732
          Just to back up what has already been said, no you can't. As soon as you enable the wireless card in the machine, it will disable the ethernet port on the machine.
          If you print out a NIC config page with the ethernet enabled and then enable the wireless option and print out another NIC config page, you find that the MAC addresses change. The MAC address changes to what ever option is enabled.
