Estudio Controller GL-1020
  • Jack123
    • Jun 2025
    I am doing a recovery on my GL-1020 controller and when I get 50% (approx) way through I get error. After the error the process bar skips to 100%. Also it is a brand new hardrive and the partition cd works fine. The Error is listed below. Please advise.
    Something to this effect
    "HDC command error: {DriveReady SeekComplete Error} "
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    what size hard drive are you using? These only supported 20-40 gig drives and then only the correct heads-sectors-cylinders or they will give this error.
    • ivovb
      • 695
      In addition to Mr Spock,
      check drive setting - some of them working with master some with cable select setting.
      BR
      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
      • Jack123
        Ohhhh Thanks for the info... you happen to know Master or Cable Select effects it too?
        I was using like an old 250 gig I had laying around.
