estudio233 - Edit Scan to file defaults?
  • copitron
    Is there a way to edit the default scan to file settings? The default setting is currently set to scan as TIFF and I would like to set it to PDF.
    I don't want to create an alternative template for users to select, I want to change the standard default settings.
    Looked all over the TopAccess pages but couldn't seem to find anything to change this.
    Any help is greatly appreciated.
  • emujo
    • Jun 2009
    • 3009
    Not sure about the 233, but 08/219 set to 1 defaults scan to remote 1 or 2 and shared HDD to PDF for most ebridge 1,2 and 3 boxes. EMujo
    • ivovb
      • 695
      Look at 08 mode codes. There are several codes for the file format setting depending of which scan method you are using.
      BR
      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
