E-Studio Controller
  • Jack123
    • Jul 2025
    E-Studio Controller
    I installed a new hard drive, new software and I can ping the ip address of the machine. However, when I hit the Network/Printer button the machine says "starting controller.. please wait...". after a min or two it goes back to the copier main screen. Can someone please help me.
    Also, when I connect a monitor to the machine everything passes "ok" and then the screen loads localhost login.
  • ivovb
    • 695
    Which e-Studio and controller you have?
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • Jack123
      GL1010
      • emujo
        • Jun 2009
        • 3009
        Did you load ver 1.xxx or 2.xxx? If ver 2, did you run the partition CD 1st? Did you remember to connect the small 2 or 3 pin harness that runs from the GL1010 motherboard to the SYS bd on the mainframe? If I remember correctly, if you are at ver 2.xxx and watching the controller boot on a monitor, you should see the boot process, then nothing but a small off white 5x5 screen. Not sure what you are seeing when you mention local host login. If you can get a pic of this please upload it. EMujo
        • Jack123
          Here is a picture of what is on the external monitor when everything is done booting.
          And when I press the "Network/Printer" button on the copier it just says "Starting Network Controller... please wait..." then after a min it goes back to the home screen of the copier.
          • ivovb
            • 695
            It is ok because machine has reached all reset time-out and the default screen is copy.
            Maybe you have to wait about 10-20 min after copeing from upgrade CD in order files to be expanded and so on. Ping to controller only means that network card of GL is working.
            BR
            • RyanPacific
              Linux Ninja
              • 97
              You may need firmware
              One thing that can stop the GL series controllers from booting up to a usable point is memory if you haven't tried that already. Also keep in mind the firmware on the main body of the copier has to have firmware that is compatible with the version of the software on the controller. I've seen controllers act exactly like you describe because the firmware on the engine isn't compatable with the software version of the controler.
              Service Business Equipment
              New, Used, Refurbished Copy Machines and Printers
              Copiers in Seattle, Kent, Tacoma and Bellevue
              • emujo
                • Jun 2009
                • 3009
                I have done many software reloads on both the 1010, and 1020s. I have never seen this message. Are you reloading the ver 1.xxx or 2.xxx software? And are you sure of its authenticity. The software will be either WINNT or Linux.
                • Mr Spock
                  Vulcan Inventor of Death
                  • Aug 2006
                  • 2064
                  CentOS is a server version of Linux. I bet he confused "linux" version as being able to use any linux and that is what happened. He needs to use a Toshiba recovery cd and reload it.
                  • aalex_bom
                    • Jan 2008
                    • 214
                    reload and reinstall
                    Mr Spock say correct, you must replace new CD 2, and run CD 1st again
