I have a e-studio 550 for a while, now "Service recommended for spc" appears on screen every 4 second, eventhough the copier is working fine, the metter is almost 300k, thanks in advance
"Service recommended for spc" appears on e-studio 550
If you are an end user and the copy quality looks normal, I would tell you to ignore it until the next time you need service. The Surface Potential sensor doesn't really do that much and usually if it has a problem, it affects your image quality. Also if it were to be defective, we usually just turn it off as the machine doesn't care much that way.
If you are a tech, I'd say reset the sensor (08-420 to 0), clean it and inspect components around it. If the code returns, disable sensor (08-421 set to 1) and go about your business.
