Toshiba E-studio 210c Access Code
  • loopylee
    • Jun 2025
    Hi All, I bought a Toshiba E-studio 210c copier and it keeps asking for a Access Code... Tried 123456 etc but can't get in.
    Is there a way of resetting the Access Code, I need help urgently....if anyone can help be much appreciated..
    Lee.
  • Harry
    • 228
    Try 08 -263 That show the passwort
    Good Luck
    • loopylee
      Hi Harry thanks for your reply.
      I have tried the 0 + 8 to get into the copier, and I can get as far as entering 263, this then takes me to a screen with the following:-
      100% 263 SYSTEM MODE
      4 4
      But I can't see anything that tells me the Admin or Access Code, I have tried everything from 123456 etc, but each time I do this the screen go's back to number 4. should I be doing something else, have I done it wrong, should I press the print key, or the button with the key on?
      I am new to this and could do with the simples first.
      Lee.
      • Harry
        • 228
        try 44 i dont know if e 210c is an e brige2 model this Type was not saled here in Italy If it is 263 show the actual Admin passwort. So try 44
        Good work
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          This is not an ebridge model and that will not be the passcode. On that machine the code is 4 digits long and was either 1234 or 0000 as a default. Also are you looking for the network code or admin code or a department overide code???
          • audioimaging
            • Jul 2009
            • 73
            set 08-600 to 0 to get rid of user codes.
            o8-653 tells you the admin passcode.
            • loopylee
              Thanks so much audioimaging...this really helped and I was able to see all the codes that were on the machine. now I have got in I can use it.
              Just looking for info on how to connect to a pc, seems there was a cd when it was a new machine but I need to try and locate one now as it has an internal fiery rip.
              • loopylee
                Fiery Software
                Just thought I would update you all, I had no installation cd for the copier for connecting to a pc for the fiery,
                If you are looking for the software go to EFI Color Print Management Software Digital Printing
                you will have to register on their site but it only takes a minute, once you have registered you can go to downloads and in there you can download all the software you need for your operating system.
                Just thought it may help a few of you, I would presume it looks like it covers quite a few fiery controllers so you should find what you are looking for.
                Took me 3 days to hunt this down but worth it.
