I recently moved a toshiba copier from one location to another and I believe that I damaged the HDD.
The OS will not boot.
In checking the drive itself I have found that it is intact, however the winnt\system32\config\system and software files have cyclic redundancy errors. I have tried to correct using chkdsk. This did correct the CRC's but left the files with corruptions that still will not allow the system to boot.
Where would I find recovery disks and what disks will I need?
Any and all help will be appreciated
Thanks in advance for your help.
