Toshiba E2500C C445 code
  • multitech
    • May 2025
    Intermittant c445 code. firmware at ver 314. Fuser is rebuilt. Thermopile good. Anyone had this problem.
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    What was the status counter in 08-400
    did it do it b4 fuser rebuild?
    I fix copiers ...Well Sorta
    • multitech
      c445
      08 sub code was 52 which is C445. machine did it before rebuild. different fuser rebuilt and installed
      • fireater
        • Apr 2006
        • 253
        08-400 was 52? hmmm not in sercvice manual
        • ToshibaTech
          • Apr 2007
          • 580
          I can't remember the codes I got in the past but if you just rebuilt the fuser check the AC wire going to the LHR lamp. If you don't watch when you put it back together it will get pinched and eventually short to ground causing some code or another.
          I will not give you service manuals or firmware.
          • fireater
            • Apr 2006
            • 253
            i used to have techs put the wrong length screws in the e-16's and e 230 lamps .. they would bottom out leaving a loose connection on the lamp ends
            but..
            1,2,3,4. Check the thermopiles, Heater and LGC board
            Check the above components following the procedures 1, 2,3 and 4 for [C411/C412].
            5. Clear the status counter
            Change the current status counter value (08-400) "3", "5", "6", "9", "19", "21", "22", "23", "24", "25", "27"
            or "29" to "0" for [C44X], taking the same procedure as that for [C41X].
            - The error occurred during warming-up: "3", "5" or "6"
            - The error occurred after the equipment has become ready: "7"
            - The error occurred during printing: "24" or "25"
            - The error occurred during energy saving: "27"
            - A paper jam occurred: "29"
            there is no 08-400 status code of 52 i can find..
            now a 25 i can see ... if its 25 i agree check for shorts to ground... sound like a lamp is staying on... youmay have to rig the door and look at all three lamps (if possible) see if they all turn on and off by using the proper test command
            side note i notice in manual page 15-10
            Remark:
            may possibly have been ruined due to causes such as leakage from the chargers.
            Check the bias, high-voltage transformers and needle electrodes to see if any of them is defective,
            and also look through all the data in the NVRAM.
            • emujo
              • Jun 2009
              • 3009
              You may want to check the machine side fuser connector. These can crack from techs shoving the fuser back into place a little too rough. Difficult to replace as it requires repalcing harness along with the connector. Poor connection generates this code. EMujo
