Toshiba 451C
  • renee808
    Toshiba 451C
    won't print in color, i downloaded and installed the PCL6 driver and i checked the preferences in the driver but keeps printing B&W
  • audioimaging
    • Jul 2009
    • 73
    postscript driver (PS3) will print in color.
    I believe one of the PCL drivers won't print in color (we used it as a way to control color usage in large companies) but can't remember if it is 6 or 5.
    Unless someone else follows up with more concise info (highly possible), I would suggest trying the Postscript driver to verify color printing and go from there.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      The drivers sent with th 4511 included a pcl6 that was a b/w only driver. the pcl5c was a color driver as was the ps3 driver. All the drivers shipped with the 451c could do both. Also make sure that you are using the 451c driver and not the 4511 driver. It will print but not quite right.
      • sdrawkcab
        Confused & Bewildered
        • Jun 2009
        • 317
        The PCL6 driver on the 451c is still a B&W only driver, use the PCL5c or PS3 driver, they are, by default colour, but can be set to B&W
        Some days, it's just not worth chewing through the restraints
