Toshiba e-studio 161 fault E7-16
  • resi
    • 14
    I have this error in this copier; its an old unit, and the manual tells me it's "abnormal laser output" and the replacement solution is MCU PWB. What I am asking for is: does any one have a suggestion as to what I can do before I order this PCB? Pse help.
  • shomyx
    • 36
    did you checked how motor with hexmirrors (in laser unit) work (is he jammed or jamming) does he have dust inside
    • resi
      • 14
      Shomyx,
      Yeah I have checked the operation of the polygon mirror in laser unit, by simulations 25-10 and 61-03. The mirror rotates. Pse give me another suggestion.
      • Harry
        • 228
        e 7 16
        it is abnormal laser output you have check the laser pcb not the polygonmotor check also for bad connectors arround
        good luck
        • fireater
          Repair God? not quite
          • Apr 2006
          • 253
          i would take laser out first and check the mirrors for dust.... then if it is clean sub in a laser from another machine for testing...... these machines dont usually blow boards.... but lasers have been known to go in the newer models from sharp
          I fix copiers ...Well Sorta
          • ivovb
            • 695
            Check visually for dust and clean. If it doesn't help change polygon motor module.
            BR
            I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
            • resi
              • 14
              Thanks guyz, I will try out your suggestions and get back to you.
              Regards.
