166 print problems
  • TTL
    • Dec 2008
    • 127
    166 print problems
    Hi.
    I have one of this machines and he is connected to one computer by usb cable, and sharing for more 3 computers.
    But she is with a lot of troubles with the shared computers in printing and scanning.
    If I put one print server it will resolve the problem? they are reliable?
  • k1ks
    Is the computers have the same OS? because ive encounterd same problem and there's 5 pc's connected. It occurs after 1 pc is formated to vista. And the rest is XP. SO what i did i download a new driver from toshiba that is compatible with vista and xp. And its all done, problem solved... try it..
    • ivovb
      • 695
      Not all print servers support printing with e166. There is one tested and approved - PS03a and successor - myUTN50. Google them and You will find local representative. It won't be fast as e167+PCL but it works. And it is cheaper network solution.
      Check your USB cable - it must be 3m or less. Check for quality (USB2) cables.
      BR
      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
