toshiba e studio 232
  • Owaisebutt
    • Jun 2009
    • 38
    Hello Friends,
    Can i install LSU of e studio 35 into e studio 232? It looks same but some difference in connector.Can it be done and worked well?
    Thanks in Advance
  • emujo
    • Jun 2009
    • 3009
    I know the E450/452 series have the same lasers, but the E45 wont work in the 450. The 232 is similar to the 230 and they should be interchangable, but I don't think the units are swappable between the E45 and the 232. You might be able to get away with the polygonal mirror and motor though. EMujo
    • ToshibaTech
      • Apr 2007
      • 580
      I'd like to know what you find out, even though I don't know of having a 230/2/3 with a laser that failed. Even ours with close to a million on them are still chugging.
      I will not give you service manuals or firmware.
      • Owaisebutt
        • Jun 2009
        • 38
        Dear Friends,
        Code C-A 20 Occured and i tried to resolve the issue but in vain.One of my friend suggested to replace the LSU.I dont have LSU of e studio 232.But i have LSU of e studio 35.They look similar thats y i thought to ask you friends if it will work or not.Any other suggestion to remove C-A 20 ?????
        • ToshibaTech
          • Apr 2007
          • 580
          Replacing it is about the only option. You can disassemble it (since you have no other option), and clean it out really well including the motor and air bearing with some contact/electronics cleaner and maybe some really light weight oil. But I have tried this before with basically no improvement.
          As someone suggested if the parts of the polygon motor are the same on the e-45 (I don't know if they are or not) then you could try swapping it.
          It's kind of one of those codes where you tell the customer "your machine has died." You should still be able to get lasers for the 232 but I am sure they are pricey.
