help for install e-studio45 printer with lan port
  • amirshkh
    • Oct 2009
    • 20
    help for install and use lan port for e-studio45 as printer
    i use lpt port for printing (speed is low) and i cant use a long wire
    can i use lan port for printer ?
    if i can tell me how?
    thank
  • ivovb
    • 695
    Go to printer properties of already installed driver.
    Open Ports Tab.
    Press Add Port.
    Choose Standart TCP/IP Port - Next.
    In upper field input IP address of printer. Don't touch lower field. - Next
    Check Custom. Don't touch Settings. - Next - Finish.
    Apply settings in Ports Tab.
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • amirshkh
      • Oct 2009
      • 20
      Open Ports Tab.
      Press Add Port.
      BR
      thank you
      but how can i get ip of copier
      lan port connect to hub swich
      • amirshkh
        • Oct 2009
        • 20
        i get ip but still not working
        when i input ip in explorer printer bord site is open in administor a can get seting list or job log and ... but in counter page when i hit the print boton
        show me error and when i want to print file the file is not upload
        tell me how can i fix this errors
        thank you
        • emujo
          • Jun 2009
          • 3009
          I'm a little confused about what you're asking. Do you want to print via the parallel port, or the ethernet connection? If you're using the parallel port I believe you need the GUI driveri. (might be confusing the E25 with this model) Get someone to help translate your question into something we can read. Emujo
          • amirshkh
            • Oct 2009
            • 20
            ok
            its all abut ethernet port
            • ivovb
              • 695
              As I understand you have GA-1040. You have IP address setted in GA. Driver installed and working via LPT port but not via Network port. Web interface is working (You might have ping, too). So you don't have hardware problem in GA. You miss some setting(s). Check all settings in admin mode if you miss to input something - IP address, mask...
              BR
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                You can print with LPT, you can get the web interface open over LAN.
                That eliminates a lot of things right there.
                Turn off your firewall and try printing. You may need to add an exception for printing with your firewall.
                You say "its all abut ethernet port". When you added the port for the print driver did it ask you to pick which network card and whether to use LPR or RAW? If it didn't ask you to select any settings then it autodetected port settings and your port should be fine. If it did ask then delete the IP port, disable firewall and add IP port again. Make sure LPR is enabled in the web interface.
                • aalex_bom
                  • Jan 2008
                  • 214
                  Manual
                  i think that you can find in Operater Manual GA1040
