toshiba e-550 developer bulk problem
  • alpertevfik
    • Sep 2006
    • 39
    Hello.
    toshiba e-550 in front of the metal on the drum machine developer is poured. Developer new. Developer tank no problem. What could be reason? bi yardım edin gardaş
  • makaule
    • 74
    Problem appeared after changing dev or earlier ? Did you perform 05-200 after changing developer ? Rotate the main dev unit gear by hand while holding mag roller gears - if main gear slips around the shaft then you'll have to change it, also check bias..
    • alpertevfik
      • Sep 2006
      • 39
      • nıke-reebook
        • 50
        • alpertevfik
          • Sep 2006
          • 39
          • ivovb
            • 695
            Arkadashlar write in English please.
            BR
            I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
            • nıke-reebook
              • 50
              • ToshibaTech
                • Apr 2007
                • 580
                Make sure there is not a lot of build up on the mag rollers. Scotch brite it off if there is. I wouldn't use anything on the scotch brite or at the very most alcohol. Make sure the cleaning brush and cleaning blade are in good shape in the cleaner unit.
                I will not give you service manuals or firmware.
