need help e4511
  • MUMMIM
    • Jan 2008
    • 125
    need help e4511
    hi all !
    i need help about e4511.
    how can i lock all color papers when photo and print? my custom want the only black papers on e 4511.
    are there any code or password for this proplem and can set password for only one department to photo and print color papers, the rest is only black papers ????
    pls help! if i am not done my custom shall resend this copier to me
  • TheOwl
    • Nov 2008
    • 1732
    Enable the Department Codes on the machine and enter in users that can print / copy colour. Then enter in another user which everyone can use for black and white.
    You can set output permissions (what they are allowed to do on the copier) for each user.
    Once this is done, you may then want to enable Department Code Enforcement from the web interface so that printing is locked down as well.
    Update the machine coniguration in the printer driver so that the driver knows that Department Codes are turned on and away you go.
    Everytime the customer then prints, a pop-up will be displayed asking for a code to print to the machine. This can be set in the driver so that it doesn't have to be entered in everytime.
    When you customer wants to copy, they will have to enter in a code so that they can use the machine. If they enter in one of the colour activated codes, then they will be able to copy in colour. If the customer enters in the black and white only code, then the copier will not allow the user to select colour.
    • emujo
      • Jun 2009
      • 3009
      Department codes will work, but they are a pain to work with and any additional steps encounterd by users are usually whined about. I believe the 4511 also had a black and white only PCL6 driver. Color options are not even available with this driver. It can be found on the public toshiba site.
      • MUMMIM
        • Jan 2008
        • 125
        Hi all
        thanks alot mr TheOwl and mr emujo ...
        i have done it my custom is very like it. thanks friends again.
