GL 1020
  • makaule
    • 74
    GL 1020
    How to make GL 1020 print PDF files faster.. It can take an hour to print 100 pages, when it takes 10 minutes when printing with my Minolta PP 1350.. WTF ???
  • ivovb
    • 695
    What are Adobe reader's, machine firmware's, controler's and driver's versions?
    Which driver (PCL/PS) are You using?
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • emujo
      • Jun 2009
      • 3009
      It would help to delete the logs once in a while. Each print/scan job requires the logs to be rebuilt and when they get into the thousands, the process can take a long time. Other things to try.. swap the HDD if its an older Maxtor 40gb with a Western Digital (or similar 80gb). This will require partition and recovery CDs so if you can't obtain them this option is out. I believe one of the GL10X0 updates allows for auto deletion of the logs. Go into top access as admin to clean things up. Emujo
      • makaule
        • 74
        Adobe reader ver 8, driver version 1.0.1.2, machines T340U011, controller version 2.2.6.7.
        • MUMMIM
          • Jan 2008
          • 125
          i think you can build more sdram for GL
          • makaule
            • 74
            Realy - there's one free slot on board.. One problem is to find such type of RAM nowadays but it's possible.. Thanks.. We'll see if it helps..
            • emujo
              • Jun 2009
              • 3009
              The controller is now at ver 2.3, drivers are at 2.3. With your version you should be using drivers at ver 2.2.3.1. As a test, connect to the GL via SMB (Start..Run..Type \\IP Address and OK). Double click the PCL driver and have the customer use this driver (should look like "pcl on 192.168.x.x"). At least you can eliminate a driver conflict as your problem. Controller ver 2.3 supports Vista 32 bit drivers. If you need these please send me a private message. Emujo
              • MUMMIM
                • Jan 2008
                • 125
                no away, because i live in Vietnam
