E-Studio 351C - CF30 Error
  • vasan_rsri
    • Aug 2025
    The m/c gives CF30 error after finishing the print / copy. Service Handbook says cf30 means -Reference plate detection voltage abnormality. I had replaced the Color Auto Toner sensor unit itself from a working m/c, Still the same problem. All the consumables are replaced just 20 days back only. The copy volume after replacement is only 10K (3K in color) .
  • emujo
    • Jun 2009
    • 3009
    The 351C has a revolver unit and the teeth break. If they break in the correct spot, the MFP has difficulty getting a good reading from the developer sleeve because of excessive play. Sounds like this could be the problem. Emujo
    • ToshibaTech
      • Apr 2007
      • 580
      Look for the teeth and also there should be basically zero slop in the revolver unit rotationally and front-to-back in the machine.
      I will not give you service manuals or firmware.
      • audioimaging
        • Jul 2009
        • 73
        Also had a logic board cause this once.
        • vasan_rsri
          Thanks for all your replys.I had replaced the revolver unit even though the teethes are good.I tried replacing the logic board also. Even i had replaced the harness which is coming from the logic board to Auto color toner sensor.
          Any other possible things to replace.
          • ToshibaTech
            • Apr 2007
            • 580
            Well about all you have left are the developer units themselves or maybe a warped frame causing the sensor to aim at the wrong place. There's the motor that drives the revolver as well. ... I don't think there is much else to replace unless you replace the machine!
            • Harry
              • 228
              a vasan
              A little Thing mayby it helps please perform 05-207 if change sensor also logik board it performs inizialisation and referenz.let mi know
              Good Luck
              Harry
