First time to see one of these, how easy is the drum/DV units to PM on them, or do you relplace the whole unit??
ES 3510
PM kits contain all but drums, B&W is fairly cheap, but color kit is around $600.00. PM'ing the EPUs is a little time consuming and often, when you pull the charge apart to clean/replace consumables, the plastic electrode hanger on rear side breaks resulting in down MFP until replaced. Also be sure to pull the little blue spacer from old drum and install in new drum. After PM run 05 200 (for all 4 developers) or 05 201-204 for individual stations, run 05/396, then perform calibrations, then reset counters in 6/Start (PM Support mode) EPUs are available as complete package, but too expensive for my branch to operate that way. Love KonicaMinolta philosophy. EMujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals. -
