e 16/20/25 broken heater gear
  • levino
    • Jul 2009
    • 38
    Hai all,
    most of my estudio16/20/25,the gear which rotates the heater roller(GEAR-HR/RLR) is breaking frequently,around 40k copies
    is this a manufacturing problem?
    any ideas
    thanks in advance
  • ivovb
    • 695
    It sounds quite anxiously (every 40k). Generally You have to apply special grease (quite expensive) to the boss of the gear when You change it. But I am sure that this is not your problem or it is? Also did You make PM's like Toshiba recommends? Make sure You are using the latest version of the gear 6LE95885000 (with reinforced material against breakage).
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • ToshibaTech
      • Apr 2007
      • 580
      IMO these whole machines were just about a manufacturing problem. If you get a new fuser unit they are made better. It's probably getting tight and either needs to be rebuilt before putting another gear on. The fusers are really a pain on this model.
      I will not give you service manuals or firmware.
