Estudio 6530 Doc feeder light streaks
  • toddanderson
    • Dec 2005
    • 233
    I am getting some light streaks going lead to trail only with the doc feeder machine is fine
    about 3mm wide one or two lines going lead to trail
    I have cleaned the class and switched it with a differant machine.
    The machine only have about 5000 prints
  • ToshibaTech
    • Apr 2007
    • 580
    Can you post a gray scale or color scan of the output? Also did you clean the mirrors and lens and lamp? Is the white strip for peak adjustment under the scan glass in good shape and unobstructed? Without replacing a CCD that's about all you have I think... A scan would help.
    I will not give you service manuals or firmware.
    • toddanderson
      • Dec 2005
      • 233
      Scan sample
      Here is a scan attached,
      Showing these streaks and line only using the doc feeder
      • audioimaging
        • Jul 2009
        • 73
        When you replaced the glass, did you only replace the big glass or did you also replace the small slit glass to the left?
        The adf only uses the small slit glass and any spots on that show as lines on your copies.
        The dual red lines look exactly like slit glass contamination. The other line is smaller but probably there as well.
        If you copy on the glass and can print with no lines at all, but have them with the ADF, it has to be slit glass related. Also clean the white plate that rests above the slit glass.
        • ToshibaTech
          • Apr 2007
          • 580
          Yeah I'd bet a cheeseburger that there is some little speck of dust, lint, thread off a rag in the optics somewhere. Well it's most definitely happening in the optics because the edge is erased. Clean and clean some more.
          • toddanderson
            • Dec 2005
            • 233
            I will double check all
