has anyone ever fixed error ce20??
  • gerryhuerta
    AccService
    • Jul 2009
    • 198
    has anyone ever came across the error code ce20 on a toshiba e-studio 3500c? if yes what did u do to fix it. i fixed one by adjusting the gap between the tbu drive gears, but i came across another 3500c with error ce20, i tried the same thing but it didn't resolve my problem. any other ideas? or other methods that worked for you.??
  • Paper_path
    • Jul 2009
    • 55
    That is an IQC error. There are probably a dozen things that can cause this. There is an 08 code to see which color is causing the problem. It can be anything with any of the dev units, or charges. I've even seen the 2nd transfer roller bubble and cause issues. Best thing to do is to let it run IQC and let it code out, then check the belt to see what the test pattern looks like and start from there.
    • jawir
      • Aug 2007
      • 107
      Hi,
      I have similar case like this, and solve after I replaced the Image quality sensor below TBU. before I tried to follow the instruction in the service handbook (a lot of step). but it is not working.
      try this....
      good luck
      • gerryhuerta
        AccService
        • Jul 2009
        • 198
        Great. I think this was fixed by replacing the TBU. already I will doublecheck and I appreciate the advise.
