Help me, toshiba 7650 error code A1...
  • tuanzwickau
    • Jul 2025
    Who here help me purify A1 mistake.Thank-you (toshiba 7650)
  • Boogotshot
    • 61
    A1 most likely is the main charge cleaner fault. Try checking the cleaner assembly on the main charge. They tend to bind up after a long time. Also check the worm gear on the main charge cleaner motor. Check the motor in 03 test mode.
    sigpic No! we never do that with the copier.
