E Sudio 452 Light spots
  • mrgoodcopy
    TechMgr
    • Dec 2007
    • 49
    Light spots on 452, changed transfer & sep corona & main corona copies got better but still have faint light areas. New to Toshiba, a Ricoh tech for 30 years any help would be appreciated. Thanks
  • ToshibaTech
    • Apr 2007
    • 580
    A greyscale scan would be good. Maybe one of a test chart or a sky shot. It would help us help you.
    You might check the doctor blade for build up behind it.
    I will not give you service manuals or firmware.
    • mrgoodcopy
      TechMgr
      • Dec 2007
      • 49
      Reset toner settings replaced developer, copies look great will do a follow up to check copy quality. There is probably a add toner issue.
      • ToshibaTech
        • Apr 2007
        • 580
        Sometimes the gearing in the toner hopper will wear out or get broken. There's a spring loaded gear assembly that the toner presses together when it is inserted.
        • Oystercopy
          • Oct 2009
          • 617
          Ditto with ToshibaTech. I've had to replace couplings in the Toner Hopper before myself as well. BRING A VACUUM CLEANER!!
