e-st 281c error CA20
+ More Options
Posts
  • yumacopiers
    • Mar 2007
    • 35
    I get this call in the morning...by the time I get there and cycle the power on the machine it works fine.
    Took the machine apart twice, cleand all, reset connectors. Anybody seen this problem? Please help!!!
  • jobez
    hello,
    you have a problem with your laser unit.
    Clean this unit but i think that your laser is KO.
    Have a good day
    • yumacopiers
      • Mar 2007
      • 35
      Thanks jobez...had that filing....copier has only 30k copies....
      • toshibadale
        • Apr 2007
        • 117
        I have a TON of these in the field and have never had to replace the laser. Yes they get dirty, and yes I've had to reset the connectors on some, but as a rule these laser's hold up good!
        I'd cut all the cable ties then re-tie them a little looser than Toshiba does it.
        • yumacopiers
          • Mar 2007
          • 35
          thnks toshibadale, will try this fix
