mj1101 dosent automatically staple..
  • gerryhuerta
    AccService
    • Jul 2009
    • 198
    i have an mj1101 finisher conected to a e studio 3500c and for some reason i cant staple automatically from the copier. it does allow me to manualy staple though, any thoughts?? thanks in advance.
    p.s. could my sw1 switch be wrong??? i have all 4 switches on the off position.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Is this from the print driver or from the copier screen?
    From the computer then check the config tab in the printer properties
    from the copier screen then check the 08 setting for the correct setting (1912 I believe).
    • ToshibaTech
      • Apr 2007
      • 580
      Sorry this might sound dumb but you say "automatically staple," are you selecting a stapling option from the Finishing button/screen and it is not stapling? Are the pages being stacked into the staple position and then ejected not stapled?
      I will not give you service manuals or firmware.
      • gerryhuerta
        AccService
        • Jul 2009
        • 198
        i am trying to staple from the copier,
        i can manually staple, by putting paper into the exit tray and pressing the staple button on the finisher. but i can not staple from the screen of the toshiba 3500c. when i make a copy of something that i want stapled i press what erver amount of copies i want then i press the sort button on the screen, then i choose the front staple sort button. then i hit start. once the copies are coming out of the finisher insted of the copies coming out stapled they come out one by one as if they were being sorted.
        i have also already done the input in 08 mode when i first installed the finisher pcb board, should i do it again??
        • emujo
          • Jun 2009
          • 3009
          Is this the problem you went out for or something that was induced after a repair to the MFP or finisher?
          • Paper_path
            • Jul 2009
            • 55
            When you do a sort, does the paper still stack correctly and get delivered from the copier as a stack?
            • gerryhuerta
              AccService
              • Jul 2009
              • 198
              i have solved the problem of the automatic stapleing!!!! i would like to thank all of the people that have replyed to this thread to keep it alive, all of the hints have been verry helpfull... on another note i have another mj1101 finisher that the elevator tray (the one that goes up and down) goes up and when it collects the paper it jamms when its coming down. if anyone can help it would be much appreciated.
              • ivovb
                • 695
                What is paper jam code?
                BR
                I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
                • emujo
                  • Jun 2009
                  • 3009
                  How about posting the fix to your original problem..2 way street here!!
                  • gerryhuerta
                    AccService
                    • Jul 2009
                    • 198
                    o yeah, it was actually my mistake, i did the 08-1912 (set to 1) and it solved my problem, i thought i had already done that before but it was my mistake, thanks anyways to all of the people that gave me advice. as for the error code that the finisher is giving me i dont remember it i will try and get it today and post it up.
                    • Mr Spock
                      • Aug 2006
                      • 2064
                      if it is an ea70 code then flash the finisher firmware above version 22 and set it to reverse rotate the ejection arm. On v23 and above this is done as a default on v22 you need to turn this on which is a slight pain but not bad.
