Toshiba E-Studio 3511 Firmware Installing Problem
  • tinnyjay
    • Oct 2009
    • 663
    Hello everybody!
    I have tried some times to install E-Studio 3511 firmware like this :
    1-I have formated USB Drive ( 4 GB ) in FAT format.
    2-I have copied E-Studio 3511 firmware files (sysfirm,rom,1,2,3,4 files) to USB Drive
    3-Put USB Drive in E-Studio Copier
    4-Switching on copier by pressing 4+9
    5-After this i see something like this :
    Download Strorage Update Mode
    Please wait...now Initialization
    Please help me!I need urgently!
    "Who loves the roses,must also bear thumbs"
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    wait 5-10 minutes....
    • tinnyjay
      • Oct 2009
      • 663
      I wait maybe 1-2 hours!!!
      • Mr Spock
        • Aug 2006
        • 2064
        The thumb drive probably has a hidden program on it called U3. If it does then a format will not remove it and this will not allow it to work. You will need to find the U3 remover online and then try again.
        • tinnyjay
          • Oct 2009
          • 663
          ITs a SILICON POWER Usb Drive and has no U3 software installed.
          • emujo
            • Jun 2009
            • 3009
            Your thumb drive is too large. Nothing larger than 1 gb for ebridge 1. Largest I've tried for newer ebridge is 2 gb. Also, ensure the drive is formatted FAT, not FAT32. You may have to fine an older laptop or PC if FAT is not an allowed choice. EMujo
            • tinnyjay
              • Oct 2009
              • 663
              I'have formated FAT with HP Format Utility.
              But as i looked for this problem,seems to be problem of USB drive storage.
              Toshiba recomends USB Drive 128 MB.
              THank you
              • bojans
                • 1313
                i did it with 512 MB USB Drive
                • Mr Spock
                  • Aug 2006
                  • 2064
                  I have used 128mb, 256mb, 512mb and 1gb thumb drive. When you say you used the hp format utility what do you mean? With the thumb drive in the computer do the following. (with nothing worth saving on the drive).
                  open my computer
                  right click on the thumnb drive
                  click format
                  use the drop down to select fat or fat16 (both are the same)
                  select yes to the popup about losing data
                  wait a minute or 2 for the format to finish then transfer the files and run the firmware update.
                  • tinnyjay
                    • Oct 2009
                    • 663
                    Everything is ok right now,because the E-Studio 4511 where i tried to install firmware,had Board problems and i am using it for parts right now.
                    In E-studio 3511 i installed correctly new firmware,using a 256 MB Flash Disk.
                    Thank you so much
                    • MiguelRT44
                      Thank you so much
                      please I need firmware for E-Studio 4511 from where i can get thanks
