who met this trouble with Toshiba E203?
  • ifback
    • Feb 2006
    • 52
    hi,everybody.
    i met this trouble with Toshiba E203,
    i dont know how to solve it.
    my machine, when i power on to start it but just number 0 appear,and blink.i wait it changes to 1 for copy but not.just blink
    No error appear,no adjust anything.On panel,i can't press anything.no warning when i open doors or toner out.
    i don't know what happen is going on.
    who met this trouble?Plz help me.
    thank a lot.
    Welcome to Vietnam
  • ifback
    • Feb 2006
    • 52
    sb help me.plz
    • Boogotshot
      • 61
      Sounds like a firmware issue (As in you don't have any) try using a recovery jig to update the firmware and see if that fixes the problem.
      sigpic No! we never do that with the copier.
      • Boogotshot
        • 61
        Sounds like a firmware issue. Try using a recovery jig to update the firmware. Do not try the USB jig. It more than likely will not work.
        • ifback
          • Feb 2006
          • 52
          thank you.
          but everything ok.but i dont know why it's ok.when i return machine after 1week,so it's ok.
          • jawir
            • Aug 2007
            • 107
            Hi,
            Some times you can fix it by take out the SRAM and wait for 3-5 minutes. After that install it back again. some times this way can solve the problem.
            rgds
            Originally posted by ifback
            hi,everybody.
            thank a lot.
            Welcome to Vietnam
            • jawir
              • Aug 2007
              • 107
              Hi,
              Have you try to reset it? try to reset it first.
              rgds
              • ifback
                • Feb 2006
                • 52
                Originally posted by jawir
                Hi,
                rgds
                thank jawir
                but i dont know how to reset it?may be you help me?
                • jawir
                  • Aug 2007
                  • 107
                  try use 1+3+*. press together than turn on the machine.
                  rgds
