toshiba studio 211c compatibility of toner
  • javier4065
    • Feb 2007
    • 251
    Hello friends, I need information about this copier for toner alternative, The customer put in toner for canon clc 1150, the dysplay shows cE4 error. thanks for your answers.
  • ameritech
    • 96
    The Canon toner is not compatible with the Toshiba, (CE4) Image quality control test pattern abnormal, you would have to replace the developer on that machine, I've search for alternative toner for Toshiba E-211, but
    no compatibles are currently available, but I know the e-210/310 is the same, except for the container that holds it. Hope that helps.
    • javier4065
      • Feb 2007
      • 251
      thanks americatech you are right. I have to change the developer and toner.That's the reason because display shows ce4.
      • tinnyjay
        • Oct 2009
        • 663
        Toshiba E-Studio 211c/311c/2100c/3100c
        "Who loves the roses,must also bear thumbs"
