Hi all,
I'm having an issue updating the firmware on an e-Studio 450. We replaced the hard drive on the machine and downloaded the firmware w/ instructions from our supplier, but I am getting errors when trying the firmware update.
If I copy just the rom.bin file from the rom-bin directory and start up with 4-9 then it says "Error, replace usb device".
If I copy the contents of the 350-450 file to the USB drive (formatted as FAT - not FAT32) then start up with 4-9 it tells me that it's initializing and after about 3 minutes it stops and says "Infalte error, please change USB strage"
I'm not sure what's going on here. We followed the instructions for setting the HDD partitions first, and the copier starts up but TopAccess does not appear,yet I can set the IP and ping it. It also will not print any lists or other info from the control panel.
This copier has print, scan and fax installed if that helps.
Thanks!
ScottN
Thanks!
ScottN
