E-Studio E35-E45: Can not print in Microsoft Excel
+ More Options
Posts
  • copylachtray
    Dear All,
    I met a same problem to print document in Microsoft Excel for both of E35 and E45 as followings:
    - O/S: Windows XP (32bit)
    - Microsoft Office 2003
    - Installed Copier Driver for Printing PCL6
    (Correct driver as instruction and support on Toshiba website)
    *Description of problem:
    - Order copier to print document in Microsoft Office, Acrobat Reader, Auto CAD...--> Done well
    - Order copier to print document in Microsoft Excel, Led of Job Status button (on control panel of copier) was turned on, and it indicate that size of the printing document is LT while I already selected its size as A4 by Paper tap in print application of Microsoft Excel. Then copier could not carry out printing job.
    Please kindly advise me how to solve this matter.
    Thank you.
  • jinxs
    • Feb 2010
    • 43
    u can try to set the printer driver's paper size default to A4
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Which controller and firmware level.
      • emujo
        • Jun 2009
        • 3009
        From waht I read, you are in an area that uses european paper sizes. It sounds like the excel document is set up for LT. Go into the page setup for the doc and cet your defaults to EU sizes. Emujo
        • craig
          service manager
          • May 2010
          • 23
          I believe you can go to the codes and set it to treat A4 and letter as the same and get rid of the issue.
          • Mr Spock
            • Aug 2006
            • 2064
            On one of the tabs (I think it is advance) look for a check box for "excel job control" unchecking or checking this may help.
