toshiba 4511 doesn't detect cyan toner at all !
  • meelmeal
    hi...
    i'm just an IT Officer, not a copy-tech guy so i honestly don't know any specific thing about copier maintenance and all ...
    but we have this big problem here at work with our toshiba 4511 copier ... it's been about 3 months that it gives us "Install New Cyan Toner Cartridge" error every once in a while. first time i thought that maybe the toner's empty so i replaced it with a new one... after about a week the error appeared on the copier's screen again and 'cuz i just bought a new one ... i bought another one but kept the old one too just in case ... but the error keeps popping ! we have a copy-tech guy who visits the device twice a week... he is good with toshiba copiers but he is as hopeless as i am ! he can't find the problem...
    has anyone else seen this problem before ?
    see ... because i replaced 3 cyan toners and the error never went away i really don't think that the problem is with the toner ... and it's ALWAYS been with the CYAN toner, not the other ones
    does anyone have any opinion ?
    tnx,
    MilZ
  • emujo
    • Jun 2009
    • 3009
    Do you have a service contract on the MFP? If so, and your rep can't get this fixed, you should look somewhere else for service. Here's whats happening....the color toners are detected by a reflective type sensor. It has gotten dusty from toner dust flying around the inside of the machine and can no longer "see" the toner bottle. The only other thing that might be the cause is you have recieved E451C cyan toner by mistake. The bottle will fit, but the notches at the rear of the bottle are incorrect for the 4511. If you dont have a finisher on the machine it's pretty easy to correct if the sensor is dusty.. 2 screws hold the inner cover in place, remove them and you will see 2 wire harnesses. One goes to a bracket that is held down by 3 screws, and 1 goes toward the rear side and is held in place by 1 screw. Remove the bracket with 1 screw, pull the sensor up through the cavity and clean it with a dry cloth. re-install and put the cover back on. If you have a finisher attached, you must remove this and the unit that directs the paper into the finisher. If you feel confident enough give it a try. Emujo
    • canonclc
      • 71
      ask the copier guy to to change the way the copier requests toner to pixel count,worked for me when i had the same problem on a toshiba 451c also with cyan!
      • michael517mi
        Toner request change to pixel
        i can't find that option in my handbook. could you tell me the setting?
        • canonclc
          • 71
          08-1506 change to 1 from 0
          • LA TECH
            • Sep 2010
            • 91
            Just clean the toner sensor located in back of revolver unit, on top, easy access is to remove the inner tray cover in the rear you'll see a screw holding the toner sensor bracket removed and pull the sensor, blow it and put it back it will work, without making any adjustments. toshiba came up with a countermeasure for this problem
            • michael517mi
              Sensor
              I have cleaned the sensor and still get "install yellow toner" message and the customer has been asked to change cyan also when it wasn't empty.
