e=3511, says "Install Color Toner Cartridge"
  • Oystercopy
    • Oct 2009
    • 623
    I believe I've seen this problem before, but usually I clean the sensor in the back of the revolver unit and its fine. I believe I blew enough canned air in behind the revolver to clean that sensor, but it's now stopped the machine cold...
    Anyone ever have any of those sensors go bad? I'm having a HECK of a time figuring out which sensor it is in the parts list.
    Thanks in advance,
    OC
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    never had a sensor die yet
    Thanks in advance,
    OC
    ok.. its been a while... the sensor u need to replace is the one that is removed from above the revolver unit ..remove the plastic cover that the copies rest on (or if u have finisher remove finisher, bridge unit,then cover) remove the screw holding the sensor bracket on and remove the sensor from machine. clean it.... test ir with 03 mode....
    [FAX] button: ON/[COPY] button: OFF ([FAX] LED: ON/[COPY] LED: OFF
    hold #2
    check "c"
    block sensor with some similar plastic as toner cartridge see if it works.
    I fix copiers ...Well Sorta
    • Oystercopy
      • Oct 2009
      • 623
      I got it... it was the color toner sensor above the revolver. Just dirty....
      OC
