3511 error code c960 pls help.
  • samolover
    • Aug 2025
    [Error Code] 3511 error code c960 pls help.
    hello
    can you please help me to fix error c960 in studio 3511?
    thanks
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    Connection error between LGC board and DRV board, ID
    abnormality
    [C960] Connection error between the LGC board and the DRV board, ID abnormality
    (1) Check if the connectors CN360 and CN331 on the LGC board are completely inserted or not
    disconnected.
    (2) Check if the connector J434 on the DRV board is completely inserted or not disconnected.
    (3) Check if the harness connecting the DRV board (J434) and the LGC board (CN360) is open
    circuited.
    (4) Check if the harness connecting the LGC board (CN331) and the high-voltage transformer (J480)
    is open circuited.
    (5) Check if the conductor pattern on each board is short circuited or open circuited.
    (6) Replace the DRV board.
    (7) Replace the LGC board.
    (8) Ask a specialist for a repair (Abnormal ID)...in other words if u did all of above call toshiba
    I fix copiers ...Well Sorta
