Toshiba Estudio 283 will not print
  • bdikeman
    [Misc] Toshiba Estudio 283 will not print
    Hi,
    I have a Toshiba E-Studio 283 that is connected to the network. I can communicate with the machine over the network, even browse the Topaccess web interface.
    The problem is, when I send a print job to the printer, it never prints. After submitting the job, I look in TopAccess on the logs/print tab and see an entry for the job, but in the "pages" column, there is a zero.
    I have tried installing the printer in a number of ways, both from a 2003 server and an XP workstation. I have manually installed the driver while creating a standard TCP/IP port, used the web install package (the web install package does find the printer,) and I have browsed via SMB to \\IP_ADDRESS and installed queues that way, all to no avail, and the same result in the TopAccess logs.
    Any suggestions?
    Thanks,
    Bo
