estudio 210c error code F10
  • xiophyte
    Hey all,
    Can anyone help me out with this? I keep getting an error code F10. I know i has something to do with the HD. Just wondering if its safe to re-format the HD even though i don't have the firmware? Isn't the HD simply used for image storing during copying?
    Any help would be greatly appreciated!
    Thx in advance
    Jon
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    you are ok to format the hdd, but it may require replacing
    no firmware should be required either way
    Happiness Is The Road.
    • belette
      hi,
      please your help, you have repaired the error if so how because I have a photocopier toshiba e-studio 210c error marked with F10 and I can not repair it. Despite the formatting of the disk by a computer F10 always present.
      thank you for your reply
      • stevemmp
        We have the same issue with a 310c
        Just wondering if you figured out how to clear the F10 code. We have the same problem with an E-Studio 310c (which is extremely similar to the 210c). We haven't had any luck with trying to repair and/or getting the machine back up and running.
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          You need to reformat the hard drive using the copier to format it.
          It is an 08 service code (I don't have it right now). If formatting does not work then the hard drive will need to be replaced.
          • Travis06
            Tech.
            • 193
            Speaking of e310/210 series. Can you use a fuser from a e210c in a e311c series?
            • ivovb
              • 695
              Yes if you have newest one version 6LA51096000.
              BR
              I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
              • belette
                Solution
                Formatting of the HDD
                <Procedure>
                (1) Turen ON the power while the digital keys [0] and [8] are pressed simultaneously.
                (2) Confirm that "Test Mode" is displayed on the control panel. Enter the code "690"
                and press the [START] key. The display changes to "System Mode".
                (3) Enter "2" and press the [SET] or [INTERRRUPT] key.
                (4) [WAIT] is displayed.
                (5) Turn OFF the power after the message [REBOOT THE MACHINE] is displayed.
