CC90
+ More Options
Posts
  • mhmsaqer
    field Supervisor
    • Jun 2007
    • 83
    CC90
    this time three finishers MJ-1022 out from the packing and the three is failed on three different machines 282,232,352.
    the error is CC90 and the exact reason "using the test mode" is the upper tray is failed to move up ,moving down is fine.
    lower tray is working both upward and downward.
    what might prevent the upper tray from going up,since there is no signal from the board to the upper motor during lifting up in the test mode.
    i've tried to ballance the trays,rails are clean and smooth.
    any ideas men?
    thanks in advance.
    Be happy for a moment - this moment is your life.
    Omar Khayyam
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Check tcn I sent a pm to you.
    • AVux07
      • Oct 2007
      • 57
      Have you ever found a CC90 solution, I'm going back weekly for phantom codes.
      • atudorica
        • Oct 2007
        • 79
        CC90 fix
        try bending bracket - see file
        • patwilf
          Service Technician
          • Nov 2009
          • 41
          Bending bracket
          I have a mj1022 that is not lifting or lowering the upper tray. U can see that the bend in the tray. But do you still have the document for that? If so can you email it to me? patwilfong1983@yahoo.com
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            Re: CC90
            If the top tray is not moving correctly i would advise changing the rail/frame with the gears on. They are on each side of the tray. If it is a case where they have been bashed etc and the tray looks unlevel you can strip it down (same procedure as replacing the frame on each side of the tray) and level the tray back up. Its a bit of a pain in the as job and a little fiddly.
            It didn't say that I couldn't do it in the manual.
