Toshiba es165 fax issue
  • pfinn10
    • Jun 2010
    • 46
    Got a Toshiba es165 that's speaking too soft in transmission level, Anyone know how to adjust this?
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    This is for an es207, which i think are almost the same.
    Machine uses binary coding to adjust attenuation levels. To get to these dip switches, from memory
    USER-->*#**->05 (THEN ENTER, I THINK)->05( ENTER)->02(ENTER)->FUNC->ENTER->FUNC4->ENTER nb. yOU MAY NOT NEED TO PRESS THE ENTERS IN (BRACKETS)
    this gets u to the binary codes. The last four digits are the ones to adjust (which means the four digits from left to right.)
    Just play around with the 1's and the 0's. Note the binary before u change it so if it makes it worse u can always go back. The worst part is waiting for a testfax to return.
    Remember this is for an es207, so ya may wanna double check before getting too far into this one.
    Anyway, hope it helps.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
