Toshiba Estudio 450 w/ mj-1023 Finisher
  • DaveCarpenter
    • Nov 2024
    [Misc] Toshiba Estudio 450 w/ mj-1023 Finisher
    This finisher is a two tray finisher, and when it is turned on and it goes thru it's post test, the bottom tray just keeps on rising until it hits the upper tray and codes the machine out. The connections are all plugged in correctly and the trays are in the correct placement. Does anyone know if there is a reset code to solve this issue or could the tray sensor on the side go bad and cause this problem?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    upper limit sensor for the lower tray. the tray position sensor on the stack/staple area.
