Toshiba 3510C error codes
  • cedcokristin
    • Jul 2025
    [Error Code] Toshiba 3510C error codes
    My 3510C is throwing a CA00 error code. Does anyone know what this means or does anyone have a list of service error codes for this machine?
  • bojans
    • 1313
    I just checked documentation about that code [CA00] Image position alignment abnormality but procedure it too long and maybe you should consider calling a tech...
    • ToshibaTech
      • Apr 2007
      • 580
      How have the copies looked lately? Color and B&W? A lot of times this code pops up because one of the developers is depleted... but it could be a wide range of problems that would cause this code.
      I will not give you service manuals or firmware.
      • cedcokristin
        The copies were fine, but the machine had a toner spill which was fixed. It was working fine again for 2 days and then went down with the CA00 error code. We had 2 techs out here for an hour tripping over each other and they could not figure it out.
        • ToshibaTech
          • Apr 2007
          • 580
          Hard to say, but dependent on how bad the toner spill was perhaps the sensors that detect registration on the belt are dirty. Just an idea... There is one at front one at rear and there is a IQC sensor in the middle. Again, there are a ton of things that might cause this error. Most of which, IMO are pretty apparent to someone familiar with the equipment.
          • cedcokristin
            My hubby was a tech for Kodak for 7 yrs and has the skills to do any procedure, but is not trained on the Toshiba product. Is there somewhere to buy the service manuals with these procedures in them?
