e520 system board/nic problem
  • Travis06
    Tech.
    • 193
    I have an e520, the copier functions work fine, but the lights on the NIC stay on all the time. I tried 08 693. Is there a hard reset like a dp2 jumper on the older ones, or do I have to replace the system board. Plugged into the network i have solid amber and green lights all the time.
  • ToshibaTech
    • Apr 2007
    • 580
    AFAIK you just have to replace it. So in that case you might try putting FW in it first. I had one of these integrated NICs go out just a little while back and there was very little troubleshooting that Toshiba could talk me through other than just replacing the board.
    I will not give you service manuals or firmware.
    • Travis06
      Tech.
      • 193
      I'm going to try a "used" system board tomorrow. Tried flashing it today, it took the flash but no luck with the NIC.
      • ivovb
        • 695
        Sometimes problem with NIC are because of bad HDD. Change and re-flash. Check also cables - data and power that goes to HDD.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • TheOwl
          • Nov 2008
          • 1732
          Things to try in order that I would.
          1. Check for duplicate IP address on network.
          2. Check switch connectivity.
          3. Try connection between machine and laptop.
          4. 693 and 1119
          5. Format HDD
          6. Replace e-Bridge board.
          Hope you get your issue sorted out.
          • Travis06
            Tech.
            • 193
            Ended up being system board. I tried the board in another machine in the shop and same thing, lights on NIC solid on with no change.
