e-Studio 453, C-580 code...
  • Oystercopy
    • Oct 2009
    • 623
    Tried two different finishers, same thing. This machine came to me with the IPC Board installed, but no finisher brackets, so I'm assuming it never did have the finisher working.... The SH says this code could be related to 08-1912, but I've set it to both 0 and 1 with the same result... Of course, even the latest e-453 SH does not say what (exactly) 08/1912 is supposed to MEAN or to do, so I'm not sure what's going on...
    Thanks in advance,
    OC
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    1912 is set to 1 with the mj1101 finisher and 0 for any other finisher. It may be the wrong ipc pwb. The mj1101 available machines needed an updated ipc to handle that finisher.
    The ipc pwb part number is 6LB12403000.
    • jamesyboy
      toner monkey
      • Jul 2010
      • 188
      the machine needs to be told that it is a 1101 finisher change the value of 08-1912
