Do you mean that the machine does not reach ready state ?
in addition to above try to check the Drum thermistor
BR,
Mohammed
serious problem several e-studio 520 series
check fuser male /female connector for damage,format hdd,check harness running under fusing unit to lwr rear connector from ih boardLeave a comment:
fuser was replaced completely, the heater control board. What he decided was the replacement logic board. I wonder whether it was possible to repair plate to be logic board.Leave a comment:
I think it is the fuser and I would check the tension screws are all the way down and the shipping screws are removed. Otherwise I would check the thermistors.Leave a comment:
There's not the machine code. And not enter into standbay.
did upgrade with jig. I copied the values of the modes of service 05 and 08 a machine that works.Leave a comment:
I can not understand your English - may be it is me.
Is there any kind of code - call for service (C..., F....), paper jam (E....)?Leave a comment:
I have many machines and studio-520,600,720,850 with the following problem:
The machines are having problems with the merger. Are stops in five minutes so ready copies and prints but not fix.
Sorry for the english but I'm using a translator. I'm from Brazil. I appreciate the help of you's.
