Hi,
We've got two problems printing to our Toshiba e-Studio 3511. As far as I know, these problems only happen when printing to the machine, not when copying or scanning. We've had two techs come look at the machine but both have poked around and, because the problems are intermittent, they haven't been able to reproduce them at that particular time and have declared the machine fine. I was hoping that maybe some of you might have come across something similar before or may have an idea of what might be wrong.
1) Sometimes, prints come out split with half the page being offset from the other. I've attached a scan of this problem as it's hard to describe in words. If you look at the attachment, the left side of the page is fine, but the right side of the page has one of the colours offset from everything else. This was from a five duplexed page job. The other pages (including the other side of this page) was fine. The problem is intermittent (maybe happening 5-10% of the time) and reprinting the page is usually the workaround.
(It's not a great workaround because it means you can't trust the integrity of the print job and you always have to check that nothing needs to be reprinted.)
2) Sometimes a print out only comes out with part of the job on it and a following page is printed with the text:
ERROR: rangecheck
OFFENDING COMMAND: image
OPERAND STACK:
--nostringval--
--nostringval--
We've been told it might be driver issues, but we've tried both the 1.70 and 1.16.12.0i1 drivers as downloaded from this page:
copiers.toshiba.com
Can anyone please help?
Thanks,
Shawn
ERROR: rangecheck
OPERAND STACK:
--nostringval--
--nostringval--
copiers.toshiba.com
Thanks,
Shawn
