e-Studio 520, not able to initialize NIC....
  • Oystercopy
    • Oct 2009
    • 618
    I've tried resetting with 08-693 and re-entering all IP Addresses... Tried reformatting HDD. No dice.... Customer believes problem occurred when they had a lightning strike (no surge protector). Firmware is at version 324, but I don't this alone would cause this. Machine was printing fine (customer tells me) prior to lightning strike....
    Thanks in advance...
    OC
  • ToshibaTech
    • Apr 2007
    • 580
    I believe the NIC is integrated on this model. You might have a blow SYS board. Try connecting a laptop directly to it, different cable, different switch port etc...
    I will not give you service manuals or firmware.
    • Travis06
      Tech.
      • 193
      Just had the same problem on a 520 last month. (also after a lightning strike) The lights on my NIC stayed on all the time, whether anything was plugged in or not. I had to replace the system board.
      • jamesyboy
        toner monkey
        • Jul 2010
        • 188
        If youre looking @ replacing the sys board try 08-669 first this will re inishallise the sys board worth a shot but its not a reccomended every day action but ive cured some weird ones with it
        • RRodgers
          • Jun 2009
          • 1947
          Thanks for the info.
